yARIC008
Drives really slow
An 83 should be a 6.9.
Dang, i thought it said 1988 not 1983, sorry. So yes, 6.9.
hmmm...
What about using a WH1C w/16cm housing gated to 12 psi (I still have my original IC from my '91)....will any of the exhaust manifolds from later 6.9 or 7.3's work on this mill? I wonder if anyone has reversed the manifolds to run in front of the motor...if so, I can fab a "Y" to the turbo mount from one of my original dodge exh manifolds to mount the turbo and then dump to the front. I can relocate the batteries to either under the front of the bed or use drop down batt boxes under the cab to give me some working space.
Are the IP's mechanical? If so, is there a thread on mod's for this? Reason I want to do these mods are:
A) I have a lead foot
B) I am constantly moving around 6 to 10k on a semi-daily basis from an elevation of 6320 up to 7k and have a lot of hills to climb.
C) I have a lead foot.
I found that my stock Dodge 6BTA was having to grunt a lot through inclines.
. I assume You know that You need a pyro before You do all this sweet stuff to that engine? As said they have good power and will get the job done now on high altitude maybe one of the guys on that area can help You out with some good info as to how much/far to turn up the fuel screw.
