ford oil pressure switch
87crewdually
Southern Nj.
Way off with the electric current flowing through the oil theory. Low voltage and amperage will NOT flow through oil to activate a gauge. The sending unit must be grounded.
TwoTone IDI
ZF swap completed!
Richmond, VA
im gonna check a few different things. first order of business is going to be rigging up a mechanical gauge just to put my mind at ease... then i will handle the instrumentation problem permanently
thanks for all the useful input guys.
TwoTone IDI
ZF swap completed!
Richmond, VA
to follow up i put a regular air gap mechanical gauge on it and saw 30 psi at idle so who knows what's up with the factory sender... other than it being a pile of junk.
ahhh life is good when things go the way you intend them to.
crispy74
