Copied from DieselPowerMag
Another reason the output of a diesel engine per cubic inch is less than that of the gasoline engine is because a spark-ignition engine can operate at a higher rate of speed. This is due to the combustion burn rate of gasoline being faster. Diesel fuel has a reduced combustion efficiency at high speeds because of the longer ignition delay, longer injection duration (in crankshaft angle degrees), and from the slow mixing rate. In diesel engines, the government-mandated smoke limits are very hard to meet at high speeds since the engine doesn't have enough cylinder event time to burn all of the fuel. Since the diesel engine has a high compression ratio, the energy required to revolve the engine itself, or what is known as friction loss, is greater than that of the gasoline engine. Therefore, when speed is increased to boost horsepower output, the friction loss raises enough to offset the output component of the engine. For a production-style gasoline race engine, a practical maximum speed is around 10,000 rpm. A similar diesel engine would only be able to achieve approximately 5,000 rpm.
So with our heavy internals where is the point of diminishing returns?
