fire wall flex fix kit
sarnhun
maxdiesel what is the part # for the pedal assembly bracket? what else do i need? have you change from plastic bushing that goes on clutch maste cylinder to brass?
M
maxdiesel
Guest
I no longer have the part # for the bracket. It's called the swing pedal assembly bracket. I got it from my local Ford dealer. I'm not aware of any replacement brass bushings. If you find any somewhere please post the source. Check for any firewall flex because thats the bracket you need to remove for the large firewall repair kit. Do yourself a favor and remove the front seat if you do this job.
