Filter head leak
NTOLERANCE
I'm the cotton swab
cottage grove, wi
The filter head in my van had alot of sealant around an area that leaked a bit. Well a bit at idle anyway. Under way it apparently leaked alot. I scraped off all the sealant and jb weld the previous owner mustve installed. What is this threaded plastic thing and how do i get it out? What seals it?
Wyreth
Certifiable Noob
Las Vegas, Nv
Sorry cannot tell what I'm looking for in the photo. Is it the plug for the fuel heater on top of the head itself that's leaking? Or is it the plugged filter sensor that's threaded into the head?
The heater plug is sealed by an o-ring and is fairly simple to swap out, or you can just thread the hole and plug it. As for the sensor, it just unscrews from the head. You're either going to want to replace it, or plug the port.
hope that helps.
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Its leaking from the plastic piece my finger is pointing to. The whole area was a big glob of goo before i scrapped it clean
zloetakoe
IDAHO
Yours almost looks like it was already plugged. but I can't tell from the photo. It "used" to have an o-ring (or some had 2 from the sounds of it). I replaced the o-ring and the leaking stopped. If it was previously plugged, I'm not sure what you could do next.
Thats the fuel filter heater like explained and several members have used JB Weld to plug that hole. Some have drilled and tapped it for a pipe plug too.
NTOLERANCE
I'm the cotton swab
cottage grove, wi
So I was thinking about it, while waitng for someone to respond, wondering why there was all sorts of goo on top.....then said to myself "Self, pull the filter off and look underneath"
Well DUH, that made sense. I was worried it was all buggered never thought to look underneath. One O ring and its fixed, thanks.
I'm not sure what happened to the top of this thing, its all mangled. Doesnt matter I guess, its sealed.
jayro88
Auburn IN
It's gonna blow up!!! Better sell it to me for $100 before it does!!! lol
It's just the fuel heater o-ring. I repaired mine about a month ago by disassembling it and putting in a new o-ring, though then you are risking it leaking agian. Since your heater is already non-functional I would just tap it and put in a plug. From my research it appears that the heater is really not needed and is somewhere around $300 for a new one IIRC.
NTOLERANCE
I'm the cotton swab
cottage grove, wi
I dunno Jayro, you might want to check my other thread on the chuff. You might not want it.!
I really dont like the filter being the highest point of the fuel system, I will likely get a different filter of some sort and relocate it.
bneumann22
