anyone have any good ideas. im going to look at my donor truck later today and want to be,able to make,sure its ok as the engine is why I'm buying the truck
go to autozone,advance,or anywhere else,,that you can get a pressure rad tester..pump it up. if it goes down..........or check for milky crankcase oil..
ok I just got done looking at the truck and yes it started but I couldn't do a pressure text cause radiator was leaking from the wreck. I popped off upper hose it is rusty but I'm getting the whole truckfor 600 bucks. 4 door longbed dually if anyone needs any parts only damage is passenger front corner and I beam and radiator anf condenser
