face cam
rancherman84
P.E.R.F.E.C.T!
clyde NY
whats the deal with LUBRICATING THE FACE CAM ON THE INJECTION PUMP?
the ops manual says about to do it about every 15,000 miles,until you reach 105,000 then you are suppossed to lube it every 5,000 miles.
what/where is this on the pump and why do i have to lube it more often after 100,000? :confused:
fiverpuller
Lizard Limo
Portland, OR
It's the lever on the drivers side of ip that changes the timing as the throttle lever rotates. Take a look...it should be the only thing on the drivers side that moves as you rotate the throttle mine has enough lube from external oil build up.
Lance
