Extended Brake Lines
87-F-250
Los Angeles
I used the search but couldn't find anything about Extended brake lines. My question is has anyone added them to their 2wd truck? If so how did you mount and run them? I plan on adding extended radius arms to get more travel so while I was doing the brakes I thought now is a good time to add them.
hesutton
The Anti-Anderson
Bowling Green, KY
I've seen them from several "lift kit" companies with various lengths......depending on the lift used. But, I'm sure they are expensive. You might be able to get a much cheaper set made at a local hydraulic shop? I have a 4 inch suspension lift and the lines were plenty long.
Like the stated above, my guess is that the stock ones will be OK.... if there is not more than 4 inches of travel change.
Heath
Optikalillushun
Coal Region, Pa
87-F-250
Los Angeles
This is on a 2wd maybe it's different than 4wd? I only lifted the front end 2-inches. When I let the suspension hang the brake lines were tight. I bent the hard line of the rubber lines where it connects to the caliper. This gave me the slack I needed. The problem is I plan on adding extended radius arms which will give me another 6-inches? of travel. I've also disconnected my anti sway bar. I am planning on adding more travel so eventually I'll need longer lines. Plus these are stainless and my old ones will eventually crack they are twenty years old. I am going for a mild prerunner look out Baja 1000.
