Exhaust manifold bolts??
EMD_DRIVER
Say what?!?!
Beaufort, SC
I went and bought another 97 F350 CCLB yesterday and it has a leaky manifold on the driver's side.
The leak is around the rear cylinder's port.
I need to remove the manifold and would like to put new bolts in it. Where's a good place to get them, for a reasonable price?
Thanks!
smokin_stroker00
dover ohio
I just got some today from a local bolt supply house 10.9 grade I think they was like $.50 each. I went to a hydraulic shop and got some viton orings for the turbo for $6 Ford wanted $194 for them
EMD_DRIVER
Say what?!?!
Beaufort, SC
Wouldn't happen to be Fastenal would it? Do you have the thread/pitch?
Thanks!
wyldhillbillie
uranus
Thanks!
did you just try to tighten it? the same thing happened to mine, just needed to be tightened
EMD_DRIVER
Say what?!?!
Beaufort, SC
I pulled the wheel and tire... Found out that the bolt is simply gone.
I took a small screwdriver and put it in the hole. From the manifold to the bottom of the hole, is 2"
I wonder if it simply needs a new bolt...
