94IDIT
Ok this is gonna be a long post so bear with me... I'm thinking about building a WVO tank out of a bed mounted tool box (gullwing behind the cab). Now I live in what is sometimes a VERY cold climate, and a complaint I hear with running just a regular tank heater, heat exchanger, HIH etc is that in extreme cold the WVO in the tank never really heats up to usable temp even after excessive idiling. That being the case I was thinking why not run a stack through the tank? I'm not really the biggest fan of them but there's no reason to waste the exahaust heat that's generated. Just cut two holes and run it through the "toolbox tank." Would that over heat the WVO and potentially be a hazard?? I don't really know what the boiling point of veg is. Or how hot a stack would get. I do know however that a mobile Ford grease fire would be the epitome of "Inderectile Dysfunction". Just a thought. Has anyone ever seen anything like this done? Also I was thinking about putting a tank heater from a livestock tank on or in the WVO tank and hook it up to a timer just like the block heater and have it kick on a few hours before I have to drive anywhere, so the veg would already be warmed up. So what do yall think? Good ideas? Bad ideas? Constructive critisism is welcomed...
