Can someone explain what this system is for, and the logic Ford uses to command it on and off? How does the the PCM know when to turn it on, and not to. What temperature is it supposed to kick on?
I'm asking because the other day the temp dropped to below 30 and it was turning on and off many times even with the engine was at normal operating temp. The gauge was between the O and R in NORMAL, which is where is usually stays, and it was turning on and off. While I was driving down the interstate, I could feel the truck losing power for a short time while it turned on.
However it seems when it's 30 or above, nothing happens, even when the engine is cold.
I would like to know if I have a problem or not. My truck is a 97 F250 PSD.
Thanks.
Thanks.
