onebadiditurbo
when you replaced the bottom radiator hose did you make sure it had the spring inside the hose. otherwise im afraid your sucking the lower hose shut and not circulating coolant. go run it hard and hold your hand to the block and sing the happy birthday song to yourself. if you cant hold it there then she is hot and your t-sensor is lying.
