Ironman03R
Tonight as I was leaving work, I idled through the parking lot and went around a corner, gave it just a bit more pedal and it took off. Almost felt like I stood on it, but it was just off idle.
Its allways reved faster with the cold idle advance on, but tonight has been the worst, I think the cooler temps helped.
Fuel system has around 50K on it and I use PowerService unless I'm running bio blend.
Is my timing off?
Is it sucking air somewhere?
Or is it normal and I shouldnt worry about it?
Is my timing off?
