engine issues
86F2506.9
6.9 International
Myerstown, PA
:confused: ok i just put new head gaskets and arp head studs on my truck we finished and had the fuel pump timing F'd up and we fixed that but the truck has no power and it dumps black if i run it down the road my question is it theres to much fuel does it decrease in power (we didnt adjust the fuel pump when we did all the work but i was wonderin if sh*t wasnt right before like when we pulled it all apart none of the head bolts were torqued and came off simple as sh*t which they shouldnt cause they should of been 80ft pounds i was wonderin why it lost so much power though now that everything is fixed right hell when it wasnt right it had more power this is ****** me off and the fuel pedal feel like it has no travel and when i floor it goin down the road it like tops out at 50miles an hour which ****'s me off cause i had it over the before its slow as f**k right now and ******* me off :confused:
:dunno plz someone help me :hail
CDX825
filtration nut
Litchfield,Ohio
Does it rattle like a powerstroke? Timing could be to far advanced.
Black smoke can be caused by to much fuel, lack of air or timing advanced to far.
86F2506.9
6.9 International
Myerstown, PA
we just got the timing lined up today its dead on matched and im guna turn the pump down tommorow and see what happens from turning it down
CDX825
filtration nut
Litchfield,Ohio
If its not timing and you did not turn the fuel up to me it sounds like its not getting enough air.
Is your intake plugged at all?
I had a similar issue once when I tried to run the a soup bowl lid with a restrictor plate style air cleaner. Went down the road and it was powerless and blew tons of black smoke.
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
"the fuel pedal feel like it has no travel "
Could your throttle cable have a problem - like at the end there is a tube like peice with a spring that could hit the outer part of the cable. I had an old cable that was bent cause me to not be able to get full throttle.
sootman73
Wauseon, OH
1. use puncuation when posting.
2. calm down and ask a question in a civilized manner.(no disguised cuss words)
3. the timing is off. the marks on the timing cover and pump mean nothing except for the original factory pump(when new) you have to have a timing meter to be able to set the timing. find some diesel shops around you're area and see if they can set the timing(and not by ear).
4. this isn't a gas motor. putting more fuel does not hamper the performance. there is no air fuel ratio on diesels so to speak. there is under fueled and overfueled. and on a diesel the more fuel = the more power.(if matched by enough air) what i'm trying to say is that turning the pump down will give you even worse performance than you currently have.
what kind of smoke are you seeing? what EGT temps are you showing?
These motors need to be timed and not just set to the timing marks. Those marks are only a starting place. You need to find a place that can use a timing meter that uses the pulse method of timing. What this is... Its a meter that has a clamp probe that connects to the number one injector line. Every fuel pulse in that hard line sends a pulse to the meter telling you what the advance or retard is. Its really the best way to time these motors.
