Years ago I put a K&N on a 3 wheeler. Suddenly I was rebuilding it 2x a year. Went back to an oiled foam filter and it ran 10+ yrs with no engine work.
Is this the literal truth?
New to the forum. Just got my first diesel; 1991 ford E350 van. Runs great, put a Hypermax 3 1/2" exhaust and k&n air filter. Did new return lines and glow plug relay. Timed it with Ferret meter at 8 degrees at 2000rpm. Egts : around town 35-45mph 400-500. On flat Texas interstates no load 65mph- 700, 75mph- 800, 80mph- 875. These are steady crusing speeds. When I accelerate from 65 to 80 temps go to 1000 then level off to 875-900. Are these temps normal ? Haven't towed anything yet and worried egts might get too hot. Egt is an Autometer sportcomp, probe is in passenger side manifold . Stock timing was at 6.5 and egts were cooler, van seems to have more pep at 8. any help would be helpful. Thanks, Fitzy
I think those temps are a little hot but my experience with NA Ford IDIs is minimal (put the turbo on my '86 in '87 when it had 7K miles) but that would be hot for my turbo 6.9L. At 60 mph, mile is about 500 and not much more at my top speed (4.10s) of 70 mph (3000 rpm). But again, My only NA/pyro experience was on a 6.2L GM.
K&N: The K&N cotton gauze filter sacrifices efficiency for airflow. It lets a lot of fine dust thru that a paper or lofted fiber filter won't. A modern paper filter l is about 97-99 % efficient on the SAE fine test dust and nearly 100 % efficient on the coarse dust test. An average 2-ply cotton gauze filter is 92-96% on the fine dust test and 97-98% on the coarse. Which test do you think they advertise? It might not be too much of a long term issue if you live in a clean air area but remember... the air intake is the primary source of contamination and wear producing particles into the engine. Want your engine to last a long time? Want your oil to stay in service longer? Make sure you run the most efficient air filtration system you can.
Read this article and make sure you read who wrote it. http://www.trailerlife.com/rv-trailer-news/the-truth-about-engine-air-filtration/
