ECU Fried?( and not like the chicken)
ccp
ahhh diesel smoke
hamilton ohio
i need some help guys i went to change me fuel filter after my truck died cps has also been changed but there are 3 discs in the bottom of the water separater connected by a wire and they didnt look right so i went to push on one to put it back where it looked like it should be and it shorted to something and sparked and gave me a nice jolt now its like my computer is fried the O/D light stays lit my dp chip wont turn on and the wait to start light doesnt even come on anyone got any suggestions on this problem this truck has fought me since day one im just about sick of it. thanks guys.
Mike
Stroker
Cora
That was the fuel heater that you shorted out. When that shorts out it blows the fuse that powers the IDM, the IDM is what powers the injectors. So, Im not sure what year your truck is but it would either be fuse #22 on a pre 99 or I think it is fuse #30 on the 99+ models. Prior to replacing that maxi fuse you should pull the wire off the fuel filter cannister that powers the fuel heater so you dont blow another fuse.
ccp
ahhh diesel smoke
hamilton ohio
still wont start no white smoke when i crank it over should the water seperator overflow when you turn the key with the cap off? cause its not doing anything so on to the next set of problems..
NJKen
is a daddy!
Central NJ
What year is your truck? If it has an electric pump (99+) you still may have a blown fuse. If it is a 97 or lower you have a mechanical pump and need to look elswhere for the lack of fuel flow (could still be the pump). If you crank the engine with the cap off you should have fuel everywhere.
I would not think that the PCM is toast just yet.
Ken
geonc
SPIDER BAIT
NECKVILLE North Carolina
have you checked the IPR-directly below and behind the filter- you will not start if that somehow got damaged or the wire got disconnected!
{don't ask me how I know this :angel: }
ccp
ahhh diesel smoke
hamilton ohio
its a late 99
well i dont think its pumping fuel i replaced 2 fuses i dont know what the other one was it cranks over but still wont start i cant remember what number the second fuse was it was on the far right from the drivers side underneath the 5 amp fuse first 5 amp from the top that is
update i just went out to check to see if fuel would go everywhere and no its not all the wires look good a little oily on the back one but i wiped it off and still no go on the fuel any fuses or relays to check would it be the fuel pump?
geonc
SPIDER BAIT
not being overly familiar with the Stoopr Doopys, have you crawled under the truck and have someone turn the key and actually feel if the fuel pump is working? :popcorn
ccp
ahhh diesel smoke
hamilton ohio
nope it was about -2 degrees here today and i cant get that motivated to do that right now but i was gonna do that tonight and im trying to figure out what relay it actually is anyone know?
ccp
ahhh diesel smoke
hamilton ohio
good call i just checked it and the pump is running but still not pouring fuel into the water seperator im at a loss now
Double-S-Diesel
parts seller
derry pa
gelled fuel.
get some 911 and fill the fuel bowl, then dump some in the tank.
must install the fuel filter or fuel will not flow out of the housing to the motor.
did ya get the WTS light to come on yet?
ccp
ahhh diesel smoke
hamilton ohio
yep got the light on now it was a fuse, just fill the bowl, not to sound like a ******** but thats the water seperator? and dump some in the tank? the little discs on the fuel heater are lifted up on 2 of the 3 will this effect anything?
Double-S-Diesel
parts seller
derry pa
un plug the plug on the back of the fuel bolw, this is the heater.water in fuel light, that will keep the heater from shorting and blowin a fuse.
yep the fuel filter is actuall the water seperator, the fuel bowl just holds it all.
ccp
ahhh diesel smoke
hamilton ohio
ok cool im hoping that the 911 thing works i used that and diesel power anti gel to loosen things up i cycled the pump a few times im gonna try to start it tomorrow after i get out of class, damn college keeping me from my truck.
