Ebay Finds & Question About Return Lines
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
Head Gasket Set - $79.99
8 Reconditioned Injectors - $125
6.9L Rebuild Kit - $757.32
8 6.9L Pistons Bored .40 Over - $169.99
8 6.9L Pistons Bored .60 Over - $169.99
I mean these, but wondering if you guys think this is a good set for the price. I plan on buying them if they look like they are good quality because mine are leaking and allowing air in the lines overnight so starting in the mornings can be a chore until all the air works it's way through the system.
6.9L Fuel Return Line Kit - $26.00
CDX825
filtration nut
Litchfield,Ohio
Thats about the average price for a return line set. Someone had posted a link to one that also included the olives for the hard lines. They also may be leaking down on you. I pulled line from the filter head to the IP on mine and the things just crumbled. Ended up making my own out of some fuel line but it was a real PITA.
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
I couldn't find the link to the one with the "olive" seals for the fuel filter line, but I just found this one from Pensacola Diesel... Return Line Kit - $29.00
I've heard their name on here, but can't remember good or bad opinions on them. Any opinions? I can't tell by the pic what all it comes with.:dunno
fastass350
SStock8569
Washougal, Wa
Kenneth,
I believe I have a package or two of those square cut seals, if I understand correctly what you are talking about. The ones for the feed line for the filter housing and IP?
Where are your return lines leaking from? I have tons of line, and o-rings are available at Napa, or I have a bunch. Probably have some caps too if you only need a few.
Or I can pick you up a kit, usually I pay 20 bucks for the whole kit, copper injector washers, all return line, clamps, caps, and o-rings.
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
Kenneth,
Yeah, I'm looking for one with the seals for the line between the fuel filter and IP. It's only leaking at a few of the caps (mainly driver's side front one), but I figured it'd just be best to replace the whole detup with a new kit and that way I don't have a few more start leaking later and keep doing it in "phases". I have to get this fixed because the Explorer has a radiator leak, so the truck is my only vehicle at the moment. If you can get a complete kit for cheaper than I'm finding them ($26 + $5 shipping & $29 with FREE shipping) including the cost to ship them to me, I will gladly buy the kit from you. I'm don't know how much it would be for priority shipping because I need them ASAP. Let me know. I'll try to call you tomorrow. Someone said that the GREEN clamps are the better ones to use... Anyone know if that is correct?
fastass350
SStock8569
Washougal, Wa
K I'll check today, as well as get a couple of those square o rings together. I don't know if they sell a kit that contains the square ones, I've never seen one. Least I can mail you a couple of those though.
All I've ever used what the green squeeze type clamps, and never had any trouble.
Just be sure to lube the o rings before you slide the caps over them to help avoid cutting them. I'm sure you know that though ;Really
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
When I put new o-rings on the injectors, I cut a piece of tapered plasic from a jug and covered the threads on the injectors with it and rolled the o-rings on. Worked well, and was an extra precaution to avoid any cuts or knicks to the o-rings. I have a feeling that the caps are shot and not making a good seal.
typ4
Newberg,OR
Kenneth, the falcon global parts are the best buy, I bought my pistons from, they are oem Mahle and I wont use anything else. I dont know how good the perfect circle pistons are but I do know the Mahle will take a lot of abuse.
