E4OD trouble codes
Ole BlackBetty
Norman, Oklahoma
Ok i am getting a code 62 and 67 from my code reader. The book that came with my code reader lists about 3 or 4 different things for these codes, dependant on what motor and vehicle type , car or truck. None of the motor options listed are IDI . So what do your code lists show as tje problem?
FoolhardyIDI
Arizona
This is what I pull up for the codes.
62
AXOD (KOEO only) 3/2 circuit short to ground – Transmissions
AXOD (KOEO AND KOER) 4/3 circuit failure – Transmissions
E4OD excessive converter clutch slippage – Transmissions
67
Park/Neutral circuit fault – PNP
Transmission Manual Lever Position (MLP) sensor circuit – Transmissions
(M) Intermittent Park Neutral Position (PNP) sensor fault – PNP
trackspeeder
Stone crusher.
North Branford. CT
62 is a torque converter slip code. You will almost always get this code when something goes wacky.
67 MLPS (TRS) is out of range. Either the range sensor is shot or out of adjustment.
A 67 code will give you a 62 code. So take a look at the range sensor. If its old, replace it. If its new adjust it by lining up the index marks.
Ole BlackBetty
Norman, Oklahoma
Trackspeeder, by range sensor are you talking about the mpls on the side of transmission? If so this is what i recently posted about thaat will not adjust properly on my trans i have not been able to pull the pan yet and see why.
trackspeeder
Stone crusher.
North Branford. CT
Yes. MLPS is the old obsolete part. The replacement is call a Transmission Range Sensor.
Drop the pan. Something is not right. The only way to find it is doing a little exploring.
ntjapkes
