masukmetal
I changed my glowplugs and I think I got a bit of an arc when the air cleaner touched the glow plug relay.
Everything was fine with the tranny until then,
I have tryed to run codes but nothing happens,
I tested the EEC relay and its good on all circuits,
I went through my fuses and all are fine
I put in another tach sensor and its fine as well.
I could check tps and mlps but its likely both are fine they look pretty new the transmission is new as well.
How can I test the TCM to see if it has power in the box or is toast?
I am thinking its not getting power because of the situation just not sure where to look to fix it.
