FORDF250HDXLT
uncle!!! chip truck -
code 23.i just changed the TPS in hopes it would fix the issue but nope.my TPS voltages will keep changing on it's own.i'll dial it in to 1.20V idle/4v WOT go for a test drive and can tell it's not right with super soft shifts right off the bat.so i'll test the TPS again and it's like 1.03 idle for example or something else odd ball.I'll re-adjust and end up with the same thing in just 1 minute.the screws are not loosening up physically or anything.it's electrical.i'll check the ground via ohm and it's very little to nothing and the other wire is over 5V so seems good there.what's causing this?
she'll lug and smoke like a fright train right now too even with the smoke puff limiter.to combat it i'll cancel od pre hill.the most irritating thing is the mushy shifts and 2-3 and lockup are right on top of each other.it's really nasty.
this just started a few days ago.head scratcher.the od light finally started flashing.i got the 23/14/62
62 is because it's not shifting right due to the tps i dunno about the bad tach sensor? i just tossed the new and good one on out of log truck just for giggles but no change but not gunna leave out the code info in case it helps.
edit;
my only guess are a bad ground or a bad TECA.i dunno.uncle!
oh and i can't try the TECA in log truck to test because it's the f450 TECA i had a pickup one in there back along but traded it out with someone.so it won't work in a pickup....well.it wont shift right and the od light would flash cus it will loath the 3.55's...but if the TPS read steady.........
edit;
