E-Fuel Conversion and New IP!
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
E-Fuel Conversion and R&D IDI Performance IP!
IP is done as is lift pump(leaking). E-fuel conversion and R&D IDI Performance 90cc IP time!
I am going with a new OEM lift pump found on the '98-'03 7.3L superduties. I ordered it from Strictly Diesel
89dieselbko
patton pa
im curious, why did you go with the R&D pump over a moose?
My engine is completely rebuilt :) but went way over budget, and have to get some other **** settled before the old lady will let me get a new pump to throw on it...
R&D cheaper? more fuel per buck? i dont even know the CC on a stock pump, and im to lazy to search, just looking at options for a few months from now
theguruat12
Certified Tinkerer
Albuquerque, New Mexico
What are the flow specs on that Holley? I like how you mounted it straight into the filter header, no extra brackets to mess with.
'94IDITurbo7.3
HAMMER DOWN!
flow as in gph? i have no idea. pressure it is 4.5-9psi. 3/8" NPT fittings.
i was originally gonna mount it on the back side of the coolant filter bracket but once i got to looking at things, i realize how tight the brackets were and stuff. so i held the reg up the way i have it now and like that better.
BTW, i am going to put that plastic wire loom on all the fuel hose. need to buy some.
X 2 on the pump. Ill be real interested to see how that works. It's neat and tidy. I like neat and tidy. ;Sweet
Ah. I'm a moron. That's the regulator not the pump. So the output is 3/8 npt? Is the input just a hose barb type thing? Push the line on and clamp it? Is the regulator really necessary? I though the IP could tolerate up to like 9 psi without any major timing issues. :dunno
I still like this.
SLC97SR5
UT
Nice install, I'll be watching for the results of that new IP.
Was your core rebuilt or is it a totally new to you IP?
Are you concerned that the pump may get hot? I guess it shouldn't but you are returning a large amount of fuel if it is supplying at 60 psi.
Still intrigued. Let us know how it does once you put a few miles on it if you don't mind.
JU57US
