Dually Rear End ID?
Copenhagen383
Mustang/Oklahoma
hey guys well theres some whining comin from the back of grumpy today that i guess i finally noticed but the guy i bought this truck from put a dually axle under her and the pinion seal is leakin.. Im pretty sure it a Dana 70 or 60 but not sure and theres not an ID tag. And how do i put up pics on here so I can show yall what im lookin at? Thanks to all!
bghnkinf350
Bay Area, Ca
Dana will have a 10 bolt cover, while the Sterling will have a 12 bolt cover. If it is a Dana 60 or 70, it will be cast into the webbing of the pumpkin "60" or "70".
Copenhagen383
Mustang/Oklahoma
Oh ok well its a 12 bolt and i didnt see any numbers besideds an A with a circle around it and the number 2 beside it
gatorman21218
Ashland VA
Look at the inside of the door jam and that sticker will have an axle code. Post it here and we will decode it for you.
IDIDieselJohn
0-60....eventually
Ottawa Ontario
Heres what Dana 70 looks like
Mine to has been making a pretty loud whining noise, ONLY inbetween 40-45mph only when accelerating. Steady speed, you can hardly hear anything, and decelerating nothing at all.
No leaks. I was supose to pop the cover off last summer to service it and have a look at the condition in there. Doesn't look like it's ever been flushed out. I will do it this summer though.
Copenhagen383
Mustang/Oklahoma
you no thats kinda what mines doin to bc i dont hear it all the time but the pinion seal deff. needs to be changed but the whine isnt loud i just heared it the other day when i had the sliding back window open and thats when i noticed it
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
Did you shake the shaft near the U-joint to check for looseness? Sometimes the nut loosens ,causing leaking pinion seals & gear missalignment,which = whining rear.
