johndear720
- Joined
- Aug 1, 2007
- Posts
- 10
- Reaction score
- 0
I just purchased a "junk" 92 4700 with a DTA 360 and 6 + 1 tranny. I mostly wanted it for parts to turn my S 1800 4 door into a "newer" model truck with a DTA 466 instead of the huge gas moster. The motor has water in the oil so more than likely has a liner rotted through. I actually purchased the truck with the understanding it was a 466. Disappointed to find the 360 but the price was still right. Is it possible to get 900 to 1000 ft lbs out of the 360? Would be easy with a 466. Does the 360 and 466 share any common parts? Are the motors different lengths? I assume they are probably different blocks and not just a crank and piston change. Will all the accessories from the 360 fit a 466? Different flywheel? I can probably acquire a 466 from a dead school bus but it would certainly be missing the correct flywheel. At least the truck had the "right" transmission and AC! Long story short, is the 360 worth messing with or should I bite the bullet and find a rebuildable 466?
Thanks,
Thanks,
I just purchased a school bus with a dta 360 for parts. I have no use for the 360 as I have a DT466 in my S1900 4-door. I hope some knowledgeable person will answer your questions as I need more horses in mine.
