driving with broken springs??
dyoung14
Is getting worn out
spencer,tn
heaths truck has moose misters and moose pump, a banks turbocharger, 37 inch tires, it made 204 hp and 450 torque at the rear wheels which in a ruff estiment is 255 hp and 560 torque at the crankshaft, figureing in the 25% drivetrain loss, thats more than a second gen powerstroke!
93fordturbo
La Crosse, Wi
also, i just found out that the passenger side sway bar is connected and the drivers side is not connected. the sway bar is the "m" shaped looking thing (kinda) that sits on the rear axle and is connected to the axle and comes out on each side towards the front of the truck. It is connected to a bolt on each side... right??
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
SOme truck had them, and other trucks didn't. My truck don't have one, and it drives jsut fine without it. You can fix it and put both ends back on, or just rip it off and not worry about it.
I would take it off unless you haul a lot of loads or tow a lot of trailers.
Vincent
