cdennyb
Asmost of you already know, the headlights on these dodge trucks suck. Not that they aren't bright, just that you loose the dim beams when you switch on the high ones!
I see in a few catalogs that there's a adapter called a "brite box" or something along that line, that allows the headlights to be on at the same time, giving you lots of light which is what you wanted in the first place when you turned on the high beams, right!?
So, I take a long look at the wiring schematic for the ol' truck and figured, "Hey, why not just throw a diode in there between the high beam pin and the low beam pin?"
When the lows are on, current won't flow to the high beams, and when the high beams are on, the current WILL flow to the low ones, thereby making ALL the lights come on.
Am I missing something? I can get a couple of diodes and some wiring (or get the plugs for the headlight connection if I want to get really fancy) for a lot less than I can buy one of those "Brite box" items for! They want something like $150-200 for one! That's crazy.
I bet if you took one apart, that's what you'd find. A pair of diodes ($20.worth) and a couple of connectors in a cute little epoxy box.
Anyone have an idea on this or can give me any reasons why it wouldn't work?
Thanks guys.
Thanks guys.
