Deuce has a new toy!!!
Freight_Train
Traitor to the brotherhood
Gadsden,Al
Click the new link in my siggy to hear.....errr,Watch......I have GOT to put one of these on a IDI!!!
Freightrain
Just "B" it........
Ohio
Dang...........that sounds SWEET!
How does it pull now? Did you go anything pump wise?
Freight_Train
Gadsden,Al
well,ain't had a chance to drive it.Still rebuilding the truck.Hopefully got the last package of parts I will need in yesterday.Want to finish putting the axles back together(as you can see,the rears have the outters removed).
But pretty much the turbo only adds 3HP and 5 Ft/Lbs of torque.....stock......but that is the maximum readings.I am pretty sure it makes it pull a little better at lower RPMs...and you can tweek the fuel settings.Just like the IDI.Gotta reset the Timing.I think NA is 25 degree and Turbo is 20...Might be the other way around.Not sure.Gotta find the TM for it.Want to take it for a spin and see if a trick someone told me works....Mothballs down the stack......hee hee hee.
MadScientist
