What is the track bar you guys talking about? Is it something that's on 4X4 ¬ on 2WD like mine?
Another question. on my 2WD dually, I got 4" body lift & 2 1/2" suspension lift. I built all the brackets to drop the TwinIBeams down etc etc.
Last year I found a supposed to be a 4" drop (actually it was more like 2-3" compared to my original, but they called it 4" drop) pitman arm that fits '82 thru '96 or '98 or so F series & Bronco...never got it on, but when I was dealing with local alignment shop they decided I didn't need the drop pitman. The tierods, center drag links, etc all defiantly are at more upwards angle than before.
I still kinda think it may need that drop, but not sure.
When I think things out, drivers side tierod linkage is one length(shorter) than pass. side linkage. With suspension 2 1/2" lift, when steering is turned without using drop pitman, it's nearly turning quicker than before....???? I'm trying to think it all out in my mind....any input from somebody????
When they played & supposedly got front end aligned, using eccentric kingpin bushings, got everything aligned correctly....camber, caster, toe-in etc, I've still had nothing but trouble with alignment. Been back & back & finally gave up for now.
To me one thing it acts like is not enough pos. caster....really quick turning side to side running down road. Fall into curve & it cuts really quick either direction....nearly like have to be careful & not over steer.
Also road walks too...too much for comfort.
As I think things out, the alignment shop might have been with specs alright for a rig sitting still on alignment rack, but still now right when running down road.
Any thoughts
