mblaney
I have a strange problem that perhaps someone might be familiar with. My D60 has a a very loud and heavy vibration from what sounds and feels like the front left. I seems to come and go, it started out smooth this morning, hit a little bump and then the loud growl and vibs. Swerving left right - no change, brake applied - no change. Then it fades and stops. Brand new rotor and pads; caliper is free (not seized). New rim swapped and no change. The front axles are disengaged and rotate very freely. I have adjusted the bearings - no change. ***???
I am thinking of tightening the bearing a little or just swap them out. Any opinions?
The frequency does not seem to be dependent on wheel speed. No idea why the spindle bearing would do this if the hubs and t-case are unlocked but this would be easy to test. I will put a plastic tie-wrap through the knuckle to stop it from turning (assuming it is) - if the noise is gone then that must be the problem.
