crew cab rear wiring *****
nj_m715
government's finest
NE of Atlanta
so my back window quit working and it didn't take long to find the typical cracked wires in the door jam
it's hot as hell so I think I'll just patch it up for now but do you guys have any tips for fixing it right?
looks like I need to rip into the door and b pillar then cut out and solder in a new section
jeepj667
SL,UT
Don't have any helpful info, sorry. But, your crew cab has power rear windows? My 89 has power front and crank rear.
Sent from my Nexus 6 using Tapatalk
nj_m715
government's finest
NE of Atlanta
older ones had cranks, I think 94 or 95 was the upgrade
I'd call this a half @ssed patch. it doesn't replace the fatigued wire and adds a stiff section to an already stresses area
thats why i'm planning to go into the door and pillar
jpw
Any wire will work for a patch in a pinch, if you want to go into the door and the pillar and replace at all with something that lasts, silicone insulated meter lead wire is extremely flexible and works good. A little difficult to find multiple colors ( there used to be a place called easy hook you could buy multiple colors of lead wire from).
HTH
J
HarleyCummins
