Cranks but will not start Help! 7.3L DIT
ihdieselman
Diesel Mike
New Madison,ohio
Hi I changed the engine in my 99 F-250 and put the old pump and injectors with new seals in the new engine. I can't get it to start it wont even fire at all. I have fuel pressure and the oil rails are full It has a new cam sensor in it. I have cranked it a LOT and I even started it on either. Does anyone have any sugestions? I'm not getting any smoke out the exhaust at all. It is cranking plenty fast.
94f450sd
somewhere,ma
check all your fuses.back track everything youve done and make sure every electrical connection is plugged in.if you disconnected the engines wire harness at the main plug,disconnect it again and check for bent pins in the plug.
geonc
SPIDER BAIT
NECKVILLE North Carolina
I went thru this same thing a while back and I had forgotten to re-connect the plug to the IPR----just left [drivers side] and below the fuel bowl-----it is part of the harness that has the fuel bowl sender connections.
Also check fuse #22---controls fuel heater and IDM......
