Mr Clickety Clackety
I am going to attempt to salvage my two brass/copper radiators as well as flush the water jackets in the block on my 87 6.9L.
Found this tid bit of information on anorthern forum... check out post #14
http://www.jalopyjournal.com/forum/threads/best-way-to-de-rust-cooling-system.943881/
"Professional cooling system de-scaling is done with Sulphamic acid for hard water, lime and antifreeze build up.
Oxalic acid is used to remove rust.
Sulphamic acid crystals are available at the hardware store in form of 'grout and tile cleaner'.
Oxalic acid crystals are available in form of 'wood bleach'.
Containers say what acid is used and its pure acid crystals with no other additives.
Available in 16oz. containers, which gives the right mixing ratio with water for the typical car cooling system with 3-4 gallons capacity"
I'm going to attempt to hook up a electric water pump (from the pet store for fish tanks) and circulate the chemical mixtures (one at a time) through the block.
I plan to put a filter on the inlet of the pump to catch any chunks and prevent the pump from clogging.
Also plan on flushing the radiator in the same fashion. only with the Sulphamic acid solution because I doubt there is rust in there.
I'll keep yell posted with the results, hopefully by next week (I have to get my house ready for my sister and her husband to move in so I'm pretty busy lol)
