Coolant on intake manifold
dgr
sac town
Went out yesterday and noticed a small puddle under the passenger side of the engine. I drove the truck and this morning, I noticed a much larger puddle. I was short on time and only took a quick glance. I noticed coolant still dripping around the starter and I noticed coolant puddled on top of the rear glow plug on the passenger side.
Before I start digging into it this evening, is there a common area for our 6.9s to leak coolant here?
Thank you
dgr
sac town
@Thewespaul thank you for the reply. I dig deeper and here's what I've got
The controller is on the driver's side. My leak is at the rear glow plug on the passenger side. The leak is directly behind (towards the center of the truck) the glow plug. It's leaking between the head and the intake manifold.
From what I can tell these engines have a dry intake with no coolant flowing through them. However, looking at pics of the heads, it appears there is a water passage in that area that is plugged with an (aluminum?) cup and it is blocked off by the valley pan. Can someone confirm there is a water passage there? I can't imagine how else water is coming out of that area.
Hope I can post a pic in the thread. Of it works, it's coming out the seam between the silver intake and the head in the pic.
The 6.9 heads do have a coolant passage behind the intake manifold that is sealed by the valley pan, sounds like you need to replace the valley pan.
  • Like
Reactions: dgr
dgr
sac town
Sounds like fun!
Do you know if there is a cup plug in that hole that should also be replaced or is it just the valley pan sealing it off?
TahoeTom
S. Lake Tahoe, CA
My machine shop was able to thread pipe plugs into those ports. Sealing the ports with the valley pan was not ideal so the change was made to plugs for the 7.3
  • Like
Reactions: dgr
dgr
sac town
Interesting. My 6.9 has oval holes. If I ever pull the heads, I will see about making them more roundy for pipe plugs.
Replacement wasn't too bad. Of course the weather had to nudge back up to 100. I got it all torqued to 28 ft lbs and let it sit for the night. I'll torque to 35 and start putting everything back on. Sure is shiny. I should probably spill some oil on it to keep it from rusting. Maybe throw some old o rings , toothpicks and gasket pieces under there.....
Macrobb
North Idaho
So... I once did modify a set of heads for some plugs. I think they were 1/2" or 5/8"?
Anyway, I used an endmill to bore out the oval hole and make it fit the plugs. Then, I installed the plugs with a little RTV, just in case.
The plugs worked fine. However... despite trying to be careful, and vacuuming everything, I must have ended up with a few chips still in the intake runners when I reinstalled it.
I found out later when I removed the heads on that motor, because I had a couple of nice score marks up and down each cylinder from the chips...
  • Like
Reactions: dgr
Lance
