Confused about shower head 7.3 n/a
Jason1377
Arkansas
Ok might be question dumb but going to eBay list the fuel tank pick-up line like this see below
now it says for f250/350 ecoline n excursions is this the same original one or am I just misunderstanding the item description. Also two of the places ive looked the seller has for $37.50 to $53 is that about right for ebay. I believe my front tank is clogged since whenever I use it the fuel filter light pops on my rear tank doesn't n I can run it pretty to empty right passed the lil notch, truck is pure stock 7.3 n/a trying to figure shower head best option n use both tanks on a small budget.
Item description
"General: Ford 6.0 7.3 Diesel Fuel Filter Screen Strainer F250 350 Econoline Excursion OEM. 6.0L & 7.3L Diesel Engine Fuel tank Filter Screen Strainer is a Direct Fit For The Following -6.0L & 7.3L Diesel Engines Only
Thanks in advance for any information.
chillman88
Central NY
That could be air intrusion. That was my problem. Mine was a leaky quick connect.
Not sure on the interchange for the showerhead though.
Jason1377
Arkansas
Thanks I will get under there after errands tomorrow provided it's not a lighting storm an trace the lines see if there just a break,on the front tank.
Jason1377
Arkansas
The shower heads are the same up to at least 2003
Thanks was not sure if it made a difference with a psd or n/a or a can never messed with one but trying to get all parts needed to replace those n sending units,any anyth else fuel related while the misses is in good mode
Wheelsrollin
