leswhitt
Les,
Do you remember what shaft size those "lovejoy" couplers are?? I have a set from when I tried to direct couple my electric motor.(looks like 5/8")
And I too have a rotary barrel pump that could work like yours. Thanks for the pics & ideas.
I don't remember the sizes off the top of my head BUT when you go to TSC, they sell a nearly identical barrel pump that HF does. Just size the lovejoy using their barrel pump and you'll be in business.
There are two things that I left off in my previous post;
1) The HF shaft already has a hole that the set screw from the manual handle uses. Drill this hole a tad bit deeper and using the lovejoy as a template, drill another hole so that you can use both set screws in the lovejoy. This might sound confusing to read but once you're holding the lovejoy in your hand and looking at the pump shaft, it'll all make sense.
2) The TSC pump shaft is a tad smaller than the HF shaft. For a snug fit, you'll have to get the lovejoy that fits great on the TSC shaft and then drill it out some to accomodate the slightly larger HF pump shaft. The metal isn't that hard and with a good bit and a steady hand, it's a relatively easy and painless procedure. Just in case you don't get it right, get an identical sized lovejoy that you'll use for the drill. That way, you'll have a spare and can easily use the mangled lovejoy as the drill adapter. Make sense?
