Cold Weather Starting ???????
mariner45
Hixon, BC, Canada
Well, now that winter has finally arrived here in mid northern BC, things are proving to be very interesting.
Last night and early morning temperatures were minus 36 C or minus 32F and nothing worked on the old F250. Literally, nothing worked.
To get the ignition switch to accept the key I had to use windshield washer fluid in a spray bottle. When the key turned, I could get the glow plugs to cycle, but the starter would not engage - nothing but a click from the fender relay! Guess that was frozen open with those temperatures cookoocookoo. The seats were like wooden boxes - the foam rubber was that hard, it literally felt like a wood seat :eek::eek: I had the truck plugged into to a timer and the block heater had three hours of heating !!!
I have just run a fan heater to the truck cab on a second extension cord and will plug it in for a couple of hours before needing the truck. That should at least make turning the ignition switch easier - maybe.
The truck has two nearly new group 31 batteries in it - and they are presently being charged to boost the reserve.
Will see tomorrow, how the old F250 works - if it will even start. Has worked fine in minus 20 C temperatures, so this temporary blip is unusual.
I sure hope you guys in the midwest don't get the temps they we have been getting - it is a might inconvenient to say the least.
Cheers
mariner
CaptTom
ca
Cheers
mariner
:eek: :eek: :eek: :eek:
You can have it!!!
Good luck starting, more luck driving!
GreenDiesel
Austin, Texas
All this talk of block heaters and sub zero temps reminds me how close I am to the equator. supposed to get up to 79 degrees tomorrow.
Ill be working outside in a T-shirt hehe, We have had a very mild winter so far
artfd
Ohio
The few days I had to start my '83 diesel when the night was -25F I ran the block heater from the time I parked it the night before until 0530 the next morning when I had to get going. I also ran an electric space heater in the cab off a separate circuit for about 2 hours so the inside was not covered in ice.
At your extreme low temps, I figure your batteries, new or old, would have very little juice available, no matter how warm your block was. I don't remember now, but there were times years ago when I would bring the batteries into the house to keep them warm all night -- this really made a difference in subzero cold starts, although there was a lot of lifting to re-install them the next morning.:peelout
Brad S.
NW IA
mariner45,
Man thats brutal, I think some of those temps are coming for us,:puke:
But hey on the bright side the bugs aren't bad this time of year.:D
I hope things get better for you guys up that way.
dakotajeep
Patrolling
TN/ND
Electric battery blankets help keep the batteries from getting zapped in the extreme cold.
Thats where my thoughts were at. That or just go start the truck in the middle of the night a couple of times...I did that during college since a plug wasn't an option in a house of 9 guys (that electric bill would have been huge!).
Thad
gdhillon
PG...Canada
i feel for ya mariner, not to warm here in pg. I drive from my house to the airport every morning (about 20 mins) and the cab still wasnt warm. so i used my moms pacifica, i love my old girl but heated seats are awesome!
Jbevs
IDI Newb
IL
I went to start my truck today after setting for a week. I always glow twice, letting the e pump run for a bit between the glows to get the system primed. It was high of 30 F yesterday, and was 10 F when I tried to start it. I had a slow cranking speed so I didn't crank for too long. It didn't fire :( It's supposed to warm up over the weekend so I can start it then.
I really need to set up a switch to turn off the gp relay so I don't have to activate it while priming the system.
stumiister
Diesel Truck Tech
Stockton, California
WOW y'all got it tough this winter here in sunny Crapafornia it has gotten down to about
29f, I havnt had a problem yet starting my truck. I hit the GP's twice and with about two to three revs of the starter she is running.
flareside_thun
Reviving The General Tao
Tavares, Florida
Whew! I couldn't handle that much cold! It's bad enough that it got down in the low 20's a few weeks ago and my old truck was hard to start......hell one time he wouldn't start and I had to use a friend's truck.
RANOVRU
Virginia
Please send some of that cold down here! We're still seeing 50's going into Feb here and all rain. Im sick of it.
Ill take some negative * please, thanks.
Hoss6.9
V - "The BOSS"
Mongo, IN.
It was 5*F here this am.... Snow storm moving in after while this afternoon... 5-7"+ here by midnite or so.... It has been a freeze and thaw winter here so far... It is really hard to get a January thaw when the January freeze hasn't set in.... I think we are there now though.... We just had our January thaw to start the month/yr out. No snow for xmas or new years this yr... I am glad winter has finally made itself known here too.... I love the snow and the cold doesn't bother me either. I can't take the real hot stuffin temps.... I breath way better in the cold..... You can always put on more clothes in the winter but, you can only take off so much. Then someone(s) will start to complain.... We all know Travis can do the banana hammock thing in the summer but, I am not up for that.... I bet that the hammock isn't too good on a hot scooter seat in the summer sun.... Seems to me you would have roasted nuts....
crispy74
