Cold start, loud then normal- off and on
hlavery1
springfield va
My 250 PU, 7.3 1999 powerstroke has real tough ntime on cold mornings. On cold mornings as it warms up seems to have some sort of exhaust valve switching off and on. Very loud when in one position and then it switches and sounds normal. As it sits and warms up it switches back and fourth.. When you drive and still little cold valve keeps changing. When in 1 position no power then it switches and great power.
Thanks for any Help!!
idiabuse
Princeton Fl
cold thick oil is not lubricating, hpop not functioning as it would be warm. do you ues your block heater for cold start?
Javier
hlavery1
springfield va
Heater is used
Yes I use the block heater and it does same thing. After it warms for 20 Min. or so it runs fine.
THANKS
69oiler
I don't feel tardy
Chardon OH
there is an Exhaust Back Presure Valve that shuts to assist in warmup. mine was sticking shut so i disconnected it and have not had any problems since.
69oiler
I don't feel tardy
Chardon OH
when you unhook it, just pull the plug, don't unhook the linkage. i unhooked mine and it was a royal pain to get hooked back up. it can leak oil with the linkage unhooked.
