Clutches... and stuff.
Clydesdale
Nampa,Id
have two donor trucks, and three donor motors.
Bad 6.9 A has rebuilt 2wd c6
Bad 6.9 B has t-19/1345 combo, cracked tail cone (ATS turbo too!:sly)
Good 6.9 c has bad 2wd c6
C350 (recipient) has 7.5/NP435/1356 new clutch, new pressure plate, etc.
IF>>> "B" has a shot clutch, non runner and feels funky, may just need a bleeding.... can I use my NP and clutch pack to the 6.9 flywheel when I swap?
hesutton
The Anti-Anderson
Bowling Green, KY
I don't know. I do know that Ron has used a 460 T19 clutch on an 6.9 IDI flywheel. As far as the NP tranny and the difference between the clutch used with it and the clutch used on the T19?:dunno The NP tranny will not bolt to the back on an IDI, that I do know. The bellhousings are different.
Heath
Clydesdale
Nampa,Id
Well, yeah, I get that 7.5 and 6.9 have differe nt bells, I have each corresponding bell...
Believe the tranny pattern, tranny to bell is the same.. though.
RLDSL
Diesel fuel abuser
Arkansas
check out the splines on the input shafts for both trannys and the flywheel pressure plate mounting holes . I should think if they are the same, you should be able to use it,even if the splines are off you can get a disc to match the tranny and slip it in so long as the rest mounts up
Clydesdale
Nampa,Id
I have always liked the Checker Schucks Kragen interchange listing, look up your part, click "see what other vehicles this fits"... Now that O'Reilly's has taken over.. I gotta say the compatibility break down is even better...
Copied:
Beck/Arnley - Clutch Set
Part Number: 061-6144
Line: BA
Online:
Not Sold Online
Store:
Call Store For Details
Add to Wishlist
Price
$251.99 Each
Call for
availability
(208) 467-3552
Product Details
Compatibility
Line: BA
* New
* Domestic
Warranty Info
1 Year Limited Warranty
Manufacturer Information
Leading supplier of quality import replacement parts.
This part also fits:
Year(s) Make Model Engine
1983-1986 Ford E-250 Econoline [Club Wagon] V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
[Club Wagon] V8 - 7.5L vin L 460ci - 4BBL GAS OHV
[Super Wagon] V8 - 7.5L vin L 460ci - 4BBL GAS OHV
[Super Wagon] V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
1983-1984 Ford E-250 Econoline [Club Wagon] V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
1983-1986 Ford E-350 Econoline V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
[Super] V8 - 7.5L vin L 460ci - 4BBL GAS OHV
[Super] V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
1983-1987 Ford F-250 V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
[Super Cab] V8 - 7.5L vin L 460ci - 4BBL GAS OHV
[Super Cab] V8 - 6.9L vin 1 420ci - MFI DIESEL OHV
1983-1987 Ford F-350 V8 - 7.5L vin L 460ci - 4BBL GAS OHV
