wwwabbit
Mmmmm Diesel
Got to fix my clutch pedal, I read the few threads that were going on about it a little while ago, just want to make sure I got it all right.
I am cutting where I have "cut?" marked and I am grinding where I have "grind?" marked. I am not sure about the "grind" one... if I grind the bump off, does it pop out? or how is that stub held into the pedal arm assembly?
As you can see, it really needs help!
I am picking up the list of hardware tomorrow:
1- 3/8" Heim joint
1- 3/8"x1 1/2" grade 8 bolt
1- 3/8" nylon stop nut
1- 1/4"x 1/2" set screw
1- 1/4 20 nut
2- 3/8 flat washers
Crap load - grinding wheels for the dremel
1- 3/8" Heim joint
1- 1/4 20 nut
2- 3/8 flat washers
