7bicks
Is there any type of return spring on the clutch fork?
I have been chasing a problem for months now.
New clutch, pressure plate, flywheel(single mass) and throwout bearing.
Clutch still lost all play in pedal when driving down the highway and will eventually cause the clutch to start slipping under a load. It makes clutch engagement VERY high on pedal travel. This is why I replaced the clutch in the first place, I assumed it was bad, $600 later and still has a problem.
Replaced clutch master cylinder, problem still there.
Replaced clutch slave. Clutch is harder to depress, play goes away when driving but clutch did not slip this time, or yet.
The only thing I can now think I may have overlooked is the fact that something shoudl be trying to return the clutch fork?
I am out of ideas. it does not seem physically possible for the clutch play to disappear while driving down the highway without even using the clutch, but it does.
