Classic Diesel Designs 61mm drop in replacement for a banks turbo.
Kdo58
Puyallup washington
It's galvanized, not sure if I will keep it, or tape it together for jig and have someone make one out of aluminum or stainless.
Huh. Now there's an idea on where to put it.
Your turbo inlet pipe from the air filter, are you still using that hvac ducting?
Kdo58
Puyallup washington
Started it up yesterday, still have to hook up the exhaust today. Went to change my oil and add antifreeze and noticed one of my intercooler pipes was over the oil fill cap, so I moved the pipe over.
Kdo58
Puyallup washington
Does anyone have an idea how much boost I should make with a stock ip turned sll the way up? With this set up.
Kdo58
Puyallup washington
Took it for a short drive today, the ip is turned up 1/4 of the way, going to turn it up all the way in the near future, going up a short steep hill, it made 7 pounds of boost and the exhaust temperature went up to 700.
I dig it, want to install my cooler too? ;Poke
