jwalterus
Made in America
stronger clutch pushrod
I have been eating clutch pedal pushrods this winter, been going through one every time it's below -10*F, they fail right at the threaded joint in the 2-piece rod every time (lifetime warranty on the master cylinder, but those are such fun to change, I'm pretty proficient at changing and bleeding them now though, it's a 20 minute job for me )
my master cylinder died last summer, and I changed it, got the almighty "Made In China" stamped plastic body POS they sell at Oreilly, it was working until it got cold
so here's a modified version of the Heim joint mod for those of you who get stuck changing the master and get the new cheap (weak) pushrod
I'm not going to go through the entire mod, I'll just put in a link http://oilburners.net/articles/Heim%20joint%20clutch%20pedal%20mod.htm for those of you who don't know what it is
here's the new junk style pushrod, cheap metal
grade B-7 3/8" redi-rod, picked it up locally for $3/ft (4 ft stick)
outside diameter of the retaining nub on the pushrod
outside diameter of the redi-rod after grinding just the threads off, I burned up 2 dremel wheels grinding it, B-7 isn't soft, I rounded the end slightly and ground off 1" of threads
I went hunting in the junkyards for a truck with a metal bodied clutch master cylinder, bought a rebuild kit for it (new piston included), cleaned it up and put it together, the new rod slides in firmly, and comes back out with a little force, no more having to mess with the plastic clips trying to change the pushrod because it doesn't have a shoulder to slide past them, I used a grade 8 heim joint with a threaded male fitting on it, and hooked the rod to the heim joint with a coupler nut, that way if for any reason I ever manage to bend the rod, I can unscrew it easily and put in another, it also made it easier to cut the length, since I could hold it up next to the heim joint and put it into the master cylinder, just had to mark it with a soapstone and hack it off (using a grinder, if you try to use a hacksaw on B-7, you'll be there all day)
