6.9poweredscout
Bleeds IH red...
Less tires to buy and nice rust free box! I don't tow equipment so I'm not worried about weight.
Lemme guess where your DRW box was problematic, right above the wheels, ain't it?6.9poweredscout said:Less tires to buy and nice rust free box! I don't tow equipment so I'm not worried about weight.
Those can be made into bolted bed mounts easy enough, however I'd recommend against it. On the bed itself every bolted crossmember is internally reinforced where a factory bolt passes thru it to prevent it from squishing when said bolt is tightened. On the other hand none of the non-bolted crossmembers has such reinforcements, meaning if you are to punch holes and run bolts thru them you can easily collapse them. You could of course fab some reinforcement sleeves or spacers that fit tightly inside said crossmembers, but that's quite a bit of work for no real gain IMHO.laserjock said:If you notice, there is an anti squeak pad for the bed directly above it. I don't think that is actually a mount point for the bed because I think it's too small for a bed bolt.
As a side note, if you'd like to part with the quarter windows in that donor truck shoot me a pm.
At least till you open the tailgateAll one color!
That ought to help deter people from following you too close while having their high beams onCleaned up the stainless and tossed it back on...
The cut the factory links and extended them. And yes the FSD and F350 are the same.
Handles awesome with the new tires and sway bars connected. Was never a brickface fan, but this ones growing on me!
