ocnorb
IDIT
alright no more jackin around. I'm gonna need my own Nuke power station to light this thing up at night, but she won't get cold anymore.
Thats what I like about you; you don't do anything halfway!!
QUOTE]
Go big or go home, right?
That would cost 3-4 $$ per hour... be cheaper to just leave it running!
Just make sure you run often enough that that 'wax drop out' doesn't happen. All that good stuff you did won't stop the tank from doing that drop out if it sits too long.
The ole **** got a heat bath last night in a heated garage and it made her happy again. No more slushy fuel and she fired right up. I noticed some construction equipment tearing up the ground around the underground fuel tanks at the guilty fueling station. I wonder if they had some sort of water leak dumping into their fuel cells.
Sounds about right. That would help explain the slush you found in your fuel filter. If I were you, I would unload that tank of fuel like the morning after a long night out! I bet after the thawing, you have some water in your fuel separator. Now the water, if that is what the problem is, is all at the bottom of your tank. That won't be fun to get out.
Do you have the filter heater working? Just a suggestion if you do, just leave the key on without trying to start for about 10-15 minutes so it warms the fuel in the filter, then try to start. At idle very little fuel is used so it should stay running if the filter is not plugged. Turn key off then back on to cycle the GP's, see if that works for you. I've done it like that at about 15* starts every time, even my PSD starts better like that.
No i have an aftermarket filter head that has a 100w probe in it. It's powered with key on. Do you think that thing would suck down my batteries too much if I left it on for 10mins or so before starting?
