mjstef
Big Sky Country....
A few observations after digging 150' of 6' deep trench today with our new (700 hour) 420 D Cat loader backhoe, Very comfortable machine, Excavator controls are great! Loader for backfilling is among the most powerful i've seen!! It will spin all 4 tires loading dirt in second gear!!! The backhoe end of the machine is marginal at best compared to our wore out Case with almost 8000 hours on it although it is a bit faster! The reach is about 4' shorter than our Case even with the extend a hoe all the way out, This means resetting more often which sucks. Part of that is the curved main boom which won't let it lay all the way down. The only thing i've found the curved boom useful for so far is loading trucks. It also will not give very much down pressure with the boom extended for digging in hard ground. This means with our decomposed granite soil here you have to scrape and scrape and scrape some more to get a bucket full!! The outriggers are not wide enough and the machine feels unstable on slopes compared to the Case. Cat needs to go back to the drawing board on the hoe end of the machine as Case has it all over Cat there. I estimate i could have saved an hour digging if i would have had the Case on the job but i saved a half hour backfilling due to Cats WONDERFUL transmission and loader! So all in all i was 1/2 hour behind today.
