C6 still aint right!!!
Jmackk
phoenix
Hey guys my 86 F250 is still having transmission issues. Im shifting into second at 5mph and therd at 15mph. I have replaces the VRV and set it, replaced the vocuum modulartor and all the vacuum lines. Im not sure what to do from here. I even got frusterated and just started moving the VRV back and forith and nothing changed. Not sure were to go next
Go down and unplug the hose off the modulator and put a screw in it to block it. Now drive it. What does it do? It should rev way up and not really want to shift at all, but it might and it will be a very hard shift, if the stuff inside the tranny is working correctly.
Jmackk
phoenix
It reves to the governor but wont shift up. The old VRV was clogged/plugged and the the trans wouldnt shift unless done manually, now its shifting way to soon. It runs great shifting manually, runs smooth, but if im in second at 30-35 and go from 2 into D it goes right into 3rd.
The trans has a governor also that varies the line pressure in the tranny. This along with the vacuum modulator is what tells the tranny when to shift, the modulator monitors the throttle position and the governor monitors road speed. I suppose there could be something wrong with the governor in the tranny. I have worked on a turbo 350 governor in the vehicle before, but never have messed with a c6. I don't know if it's accessible from the outside like the turbo 350 or not.
Dsl_Dog_Treat
Decatur,MI
Are the lines hooked up to the vrv correctly? Has a vacuum test been done on the vrv to verify its functionality?
Jmackk
phoenix
Hiwndo i test the VRV for function? Its new but i guess that doesnt mean good. Top vac line comes from the tree and the bottom goes to trans mod. I guess i could try swapping just for S&G's
Jmackk
phoenix
Also just check and I have 23-24" vac at the line going into the VRV does that sound about right
Dsl_Dog_Treat
Decatur,MI
You have the lines routed correctly.
Have you seen the vrv adjustment thread in the tech articles?
Jmackk
phoenix
Ok so i have been out and tried setting it up again, the tech article here was much better than the other one I found. When i place my vacuum pump(hand pump) on then VRV and apply vac I have to keep pumping it to maintain vac. I check all the lines and theres no leaks. But when I apply the vac to the vrv(top) and the gauge(bottom) it will not hold pressure.
Jmackk
phoenix
Is there anything I can do to try and "fix" it? Its a brand new valve an id have to take it apart but I guess it doesnt matter since its $ down the drain anyway lol
Jmackk
phoenix
And I put in a new vacuum modulator, i bought a black stripe but when I received it there were no "stripes" on it. Just the standard gold finish with a black O ring. Is this going to have any affect on anything?
mariner45
Hixon, BC, Canada
You should be able to adjust the modulator. There will be a small screw inside the tube and you adjust it to chnage operation - don't remember which way. It is easy and simple and you really need to try the truck out and adjust accordingly.
typ4
Newberg,OR
any chance the pin fell out when you changed the modulator?
And the no stripe one may be the problem. I used to have a scale chart to set modulators to the lbs spring pressure but ill be danged if I can find it. It came from a very old guy in a trans shop and he set them this way and checked/adjusted the new ones.
The VRV has to be the Black one, the Green strip is for gassers, have no idea what a Gold one is for.
Sgtbyersfw
