Body mount bushing improvements?
larson
Springtown,texas
For they guys that have replaced there body mounts was there any noticeable difference afterwards?
I just recieved mine today but i leave for west texas tomorrow for 20 days so it will be 3 weeks until i replace them but i will. I just wanted to ask.
chillman88
Central NY
The only difference mine made is my body lined up with the bed again lol. I think it stiffened it up a little bit but nothing major. I also used urethane bushings for what it's worth.
larson
Springtown,texas
Stiffened it up? Lol thats the last thing i want. When i replaced the factory coil springs the stiffness increases drastically so much so that my wife called it out when riding with me. I kicked her out at the next stop light.
chillman88
Central NY
It didn't stiffen it in a bad way in my opinion. It wasn't like it made it ride harsher, just... Stiffened it up lol. It doesn't feel like it twists as bad going over rough ground (my yard). More of letting the suspension do it's job and less of everything else moving around.
larson
Springtown,texas
Cool thats what i need. My cab body pops a lot when it gets in a slight bind going up and over slight bumps in my driveway especially if I've turned the wheel a little during the process. It seems to have gotten way worse since i have replaced all of my sway arm bushings and new front springs. All of that stuff is a lot tighter now and its exposing the next weak link (cab bushings) and mine are all blown out visually.
Thanks for replying.
hesutton
The Anti-Anderson
Bowling Green, KY
I used Energy Suspension's bushings on my '86 crew cab. Pulling the old mount apart was really fun.:frustrate
But it made the cab and bed alignment normal again. There is less wobble over rough stuff, but the ride was not harsh.
Heath
gfemling
North Bend, OR
Replaced my deteriorated original rubber with poly ones and did notice more “creaking” when going over “twisty” ground. Concluded the poly is just stiffer than rubber and body to poly interface surface is moving/rubbing. Maybe needed more assembly lube ;-)
Not too bad but if did again I would consider using rubber instead.
Lance
