ok here the story
batt. lite came on in truck, batterrys were eventually dead.
got batterrys charged and tested, passenger was no good, driver was good batts were tested seperratley
ok, got new alternator, and 1 new batt, for passenger side should solve problem(i thought)
alternator not charging, only 12.8 volts
got alternator tested, 2 shops said it was good,
buy new vr and pigtail going into the vr
change pigtail (only wire nutted together) and new vr, but vr was not on firewall (just sitting) batterry lite was not on no more now getting 17volts at batterry
i thought maby vr was not grounded so that was problem now.
install on firewall (which i thought was a good ground) thats the way it was when i purchased
batt. lite comes back on
start truck still getting 18v at batterrys
while truck running, if i pull lite switch volts drop down to 14v
truck running, lites on rev rpm's volts in truck gage start to climb
truck still running, lites on, gage in truck steady at 14v
i play with switch to put window up and volts go up, starnge
i need some serious help with this
thanks for reading
brian
thanks for reading
brian
