battery light on,no tach,trans wont shift.
Cubey
Van dweller
heres what its looks like in the cab..
Ahh. I forgot that the other gauges say NORMAL too. It's been almost a year since I drove my F250. Vans had the late 70s F-series style cluster through 91.
Slicknik
Burbank, CA
@Nick_Rego
hmmmmnmm
I would
Clean those connectors/connections at the alternator is a start....clean your battery terminals connections, make sure the mating alternator wires are making good contact and don’t have loose connections. Then start the truck,
13.4 volts with the truck running or off ?
How much resistance is in the alternator pulley? , belt off
does the battery light stay on or does it go away and come back on ?
Nick_Rego
California
@Nick_Rego
hmmmmnmm
I would
the 13.4 is while running at idol. i also noticed this morning whith headlights on and stoped at a light with the turn signal on and heater blowing on high it would drop down to just before the N... as soon as i start moving it goes back up too the middle... I havent taken the belts off yet might even just be loose.
H3LLSP4WN
Texas
Sounds like your regulator is starting to fail or possibly a bad wire from alternator to the batteries for charge you say 13.4 but it should be somewhere in the 14-low-mid if working properly mine fails regularly but hoping to fix a ground issue causing it soon I kept replacing regulators to find out there is a short in my harness
Selahdoor
Index Wa
Brake light... Disconnect the vacuum warning switch.
Nick_Rego
California
i unplughed whay i thought made sense being called a vacuum warning switch and the light is off now. what about thst causes the light to come on?
Cubey
Van dweller
If the switch is working right, poor/no vacuum. If it's gone bad, it thinks there's poor/no vacuum even if there is good vacuum. It's supposed to warn you that you have no power brakes. Wish mine had worked when I threw the alternator belt but only heard a tiny thump at highway speed, so I had no idea. Thankfully when I went to brake eventually, it wasn't a panic stop so I was able to get to a truck stop about 5 miles away to see what was wrong.
Nick_Rego
California
my brakes feel ok probably beed to be bleed a little bit... another one corssed off the list and potentially more to come haha. i did tske the belts off and spun the alternator by hand and tried it for play seemed solid no weird hard spots or anything that concerned me.
Cubey
Van dweller
You would know if you have no vacuum. You'd be stomping the pedal with both feet and putting your weight into it.
Nick_Rego
California
haha im farmiliar with the feeling my 69 falcon is manual everything definitely not the best.
Selahdoor
Index Wa
Yup. I unplugged mine for the same reason.
Glad that I didn't confuse you into unplugging the vacuum line from it. LOL
If I lose vacuum to the point of affecting the brakes... Well, I'll take my chances on that. I'm still strong enough to stand on that brake pedal and get er stopped, if that happens.
But having that light come on all the time, affects your transmission, if you have an E4od. At least it did mine. Gave er about 50 miles after disconnecting that, and suddenly the trans started to act better.
Cubey
Van dweller
That trans doesn't need vacuum, does it? Very weird that they'd tie a vac warning light to a trans that doesn't even vac.
Selahdoor
Index Wa
The brake light on the dash, activates something else that affects the trans. My memory isn't the best.
tke395
