coletrain777
Hi guys and gals,
I am a fairly new member (slowly moving over from TDS), and I wanted to say HI and ask a few questions. My name is Cole and I currently have a 1991 f350 N/A IDI ex cab. 2wd DRW, and a 1994 F350 Crewcab, 4x4 ZF5 SRW longbed. I really like these trucks, and plan to keep the CC for a long time. It is a new ride to me (just picked it up last week) and it is great. But alas... it's got a problem. The batteries are draining overnight.
I know that I have a battery drain on the circuit that has the dome lights/ courtesy lights, odometer, door chime etc... If I leave that fuse in my inside lights are always on mo matter what. So I pull the fuse at night, and when I come out in the morning the batteries turn the starter over very slow. I have an electronic battery charger that tells me volts and battery percentage, and when I hook it up after the truck sits for a while it normally says that my batteries are only holding about a 30% charge and aournd 12 volts. The truck seems to charge fine while running, just drains after sitting. So now that you have the story, here's my questions.
1. What could be causing my courtesy light circuit to stay on???
2. Should I have any components tested (starter, alt, etc...). I live about 25 miles from Oreilly's so I cant drive back and forth more than once (hate to waste gas).
3. What tests/diagnosis steps should I do, and in what order? I am a pretty good mechanic, but a horrible electrician, so this is my worst nighmare.
Thanks for the help guys, hope to get this figured out fairly quick. Cole
