rdoimages
I have tried searching but there are 800 mentions of battery drain.
I am experiencing drained batteries after 2 or 3 days of the truck sitting unused. The batteries are brand new, the positive cable is a brand new OO cable, the alternator is nearly new and the regulator is fairly new. The only constant drain I know of is the radio memory.
Anyone have any ideas of anything else that could be causing the drain? I need to get the truck running to check alternator output I guess. It will start fine when charged and it will be good for a day or two and then it's drained enough to not turn it over at all.
89 F-350 sc 2wd DRW 7.3 ATS 088, C-6 with Gear Vendor and a rats nest of wiring that was free with purchase.
00 Excursion limited, 6.8 4x4
